Calling rtems_io_lookup_name from within an ISR
Joel Sherrill
joel.sherrill at OARcorp.com
Tue May 11 16:25:07 UTC 2010
On 05/11/2010 11:01 AM, Jamie Bowman wrote:
> All
> Hopefully this should be quite an easy one. Within the RTEMS
> Documentation “c_user” it states that the following is a list of RTEMS
> system calls that may be made from an ISR:
> * IO Management
> The following services are safe to call from an ISR if and only if the
> device driver service invoked is also safe. The IO Manager itself is
> safe but the invoked driver entry point may or may not be.
> rtems_io_initialize, rtems_io_open, rtems_io_close, rtems_io_read,
> rtems_io_write, rtems_io_ control
> Is it safe to call an rtems_io_lookup_name from within an ISR?
No. It uses the filesystem and that is not safe from ISRs.
> Kind regards
> Jamie
Joel Sherrill, Ph.D. Director of Research& Development
