building c++ samples
Gedare Bloom gedare at gwmail.gwu.edu
Sat Nov 6 20:40:03 UTC 2010
Hi,
I'm having a little difficulty in compiling the C++ samples (iostream
and cdwrite) and thought I might see if I can get any suggestions on
where I might look.  I am trying to build for QEMU/pc386, just to get
things working.
I configure with:
../rtems/configure --target=i386-rtems4.11 \
  --enable-rtemsbsp=pc386 \
  USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0
But the iostream and cdwrite samples do not compile properly, the
Makefile is created, but when the build attempts to compile in those
directories I get the following output:
iostream$ make
source='../../../../../../../rtems-diff/c/src/../../testsuites/samples/iostream/init.cc'
object='init.o' libtool=no \
	DEPDIR=.deps  /bin/sh
../../../../../../../rtems-diff/c/src/../../testsuites/samples/../../depcomp
	i386-rtems4.11-g++ -B../../../../../pc386/lib/ -specs bsp_specs
-qrtems -DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_VERSION=\"4.10.99.0\"
-DPACKAGE_STRING=\"rtems-c-src-tests-samples\ 4.10.99.0\"
-DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\"
-DPACKAGE_URL=\"\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
-DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
-DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1
-DHAVE_UNISTD_H=1 -I.
-I../../../../../../../rtems-diff/c/src/../../testsuites/samples/iostream
    -mtune=i386 -O2 -g -Wall -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs -c -o init.o
depcomp: Variables source, object and depmode must be set
make: *** [init.o] Error 1
Any ideas what I might be missing?
-Gedare
