rtems kernel
Eugene Shvets lhj7362 at gmail.com
Mon Nov 8 11:44:51 UTC 2010
 I need to boot rtems with GRUB.
There are wiki pages devoted to QEMU and GRUB. However I need a kernel image
of rtems to use grub(like when we use linux, we put linux-kernel-2.6.xy into
/boot directory). I cannot find it.
I did some search and found the same question
http://www.rtems.com/ml/rtems-users/2008/february/msg00125.html
So, I installed rtems as said in here
http://www.rtems.com/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu
However I couldn't find the image or nesessary *.exe file.
I invoked :/opt/rtems-4.10# find . -name "*.exe" -print
And got the following result:
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/pppd.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/cxx_iostream.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/paranoia.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/fileio.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/capture.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/base_sp.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/minimum.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/cdtest.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/unlimited.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/nsecs.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/ticker.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/loopback.exe
./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/hello.exe
Why these samples are stored at lib directory?
And where is the RTEMS image ? What is it named like? how can I search it?
Thank you
URL: <http://lists.rtems.org/pipermail/users/attachments/20101108/9f189ace/attachment.html>
