FW: Problems dowmloading rtems-graphics-toolkit
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Nov 9 14:51:09 UTC 2010
On 11/09/2010 06:35 AM, Kirchner, Ralf wrote:
> HiJoel,
> I am trying to download the rtems-graphics.toolkit without any success
> so far.
> Unfortunately I have to work on a Windows machine.
> This is what I have tried:
> 1.
> Download from
> _http://www.rtems.com/cvsweb/cvsweb.cgi/rtems-graphics-toolkit/_
> - If I click on link "tarball" or "zip archive" I always get the
> following error messages:
> Error: Export failure (exit status 1), output:
> cvs export: failed to create lock directory for `/usr1/CVS/CVSROOT'
> (/usr1/CVS/CVSROOT/#cvs.history.lock): Permission denied
> `/usr1/CVS/rtems-graphics-toolkit'
> (/usr1/CVS/rtems-graphics-toolkit/#cvs.lock): Permission denied
> cvs export: failed to obtain dir lock in repository
> cvs [export aborted]: read lock failed - giving up
This one I hope someone on the list has advice on. The
CVS tree is owned by user cvspserver. Apache is running
as another user. The cvsweb.cgi program does not have
permissions to write the lock into the directory because
it is running as another user.
For normal pserver interaction, you are running the service
which is running as the dedicated cvspserver user.
Any ideas out there?
> 2.
> Download via cvs from a MinGW console:
> My command is:
> cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
> I simply press enter for the password
> Then I get the following error:
> cvs [login aborted]: connect to _www.rtems.com:2401_
> <http://www.rtems.com:2401> failed: Connection refused
I don't know why this wouldn't work. No one else has seen any other issues
and I just logged in OK with a cut and paste of your command.
> 3.
> Download via cvsgrab from a windows command.com console:
> My command is:
> D:\NCS_rtems-root\home\apps\RTEMSGraphicsToolkit>c:\Programme\cvsgrab\cvsgrab
> -url _http://www.rtems.com/cvsweb/cvsweb.cgi/rtems-graphics-toolkit/_
> The result is:
> [ERROR] Failed to download file
> java.net.ConnectException: Connection refused: connect
> at java.net.PlainSocketImpl.socketConnect(Native Method)
> at java.net.PlainSocketImpl.doConnect(Unknown Source)
> at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
> at java.net.PlainSocketImpl.connect(Unknown Source)
> at java.net.SocksSocketImpl.connect(Unknown Source)
> at java.net.Socket.connect(Unknown Source)
> at java.net.Socket.<init>(Unknown Source)
> at
> org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultP
> rotocolSocketFactory.java:86)
> at
> org.apache.commons.httpclient.HttpConnection$1.doit(HttpConnection.java:660)
> at
> org.apache.commons.httpclient.HttpConnection$SocketTask.run(HttpConnection.java:1291)
> at java.lang.Thread.run(Unknown Source)
> at
> at
> at
> at
> at
> at
> CVSGrab version 2.3 starting...
> Error: rootUrl parameter is mandatory
> Error: packagePath parameter is mandatory
> usage: cvsgrab
This is sometimes flaky.
> Am I misunderstanding how getting the rtems-graphics-toolkit sources
> works or is there a problem with the server?
> I hope a little hint from you will solve the problem.
> Kind regards,
> *Ralf Kirchner*
> Nurse Call/Software Architect
> Region South-East
> *Tyco Safety Products*
> TOTAL WALTHER GmbH
> Feuerschutz und Sicherheit
> Waltherstraße 51
> 51069 Köln
> Tel.: +49 (0)221 6785-25
> Fax: +49 (0)221 6785-81
> _rkirchner at tycoint.com_ <mailto:xxxxx at tycoint.com>
> _www.totalwalther.de_ <http://www.totalwalther.de/>
> Company’s registered office: Köln
> Handelsregister Amtsgericht Köln: HRB 13472
> Managing Directors: Keith Andrew Taylor, Günter Schauerte
> Chairman board of directors: Matthias Ernst
> /A Tyco International Company/
> Please consider your environmental responsibility before printing this
> email!
> The information contained in this communication is confidential and
> may be legally privileged. It is intended solely for the use of the
> individual or entity to whom it is addressed and others authorized to
> receive it. If you are not the intended recipient, you are hereby
> notified that any disclosure, copying, distribution or taking any
> action in reliance on the contents of this information is strictly
> prohibited and may be unlawful.
Joel Sherrill, Ph.D. Director of Research& Development
