Problems building RTEMS for ARM on Ubuntu 64bit
Ralf Corsepius ralf.corsepius at rtems.org
Fri Nov 12 17:57:16 UTC 2010
On 11/12/2010 06:44 PM, rtems at soulscythe.com wrote:
> I've removed all of the prebuild binaries and downloaded and recompiled
> a newer toolchain using this script
> https://github.com/esden/summon-arm-toolchain
This will not work - This toolchain is not suiteable for RTEMS.
Your initial report indicates your Ubunty installation contains a libgmp
which incompatible to CentOS5's, even though Ubunty's libgmp.3 and
CentOS5's carry the same SONAME.
=> Either Ubunty or CentOS's libgmp is broken.
Ralf
