Problems building RTEMS for ARM on Ubuntu 64bit
rtems at soulscythe.com rtems at soulscythe.com
Sat Nov 13 01:52:07 UTC 2010
Thanks, is there a list of compatible compilers anywhere? ive searched
the rtems site but cant find anything.
Ive also downloaded the source code for the toolchain from the rtems
site, but cant find any instructions on what to do with it. I see on
this list that many people have successfully downloaded and built the
toolchain but I dont know what to do with it or where to put it. I
cant fiond any instructions on the rtems website either.
thanks
Jayse
Quoting Ralf Corsepius <ralf.corsepius at rtems.org>:
> On 11/12/2010 06:44 PM, rtems at soulscythe.com wrote:
>> I've removed all of the prebuild binaries and downloaded and recompiled
>> a newer toolchain using this script
>> https://github.com/esden/summon-arm-toolchain
> This will not work - This toolchain is not suiteable for RTEMS.
> Your initial report indicates your Ubunty installation contains a
> libgmp which incompatible to CentOS5's, even though Ubunty's libgmp.3
> and CentOS5's carry the same SONAME.
> => Either Ubunty or CentOS's libgmp is broken.
> Ralf
