Help Request: Linker errors on gdbarmsim
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Nov 17 19:14:01 UTC 2010
Hi,
It is giving out of memory errors linking hello world
on all variants.
I don't see any changes or anything wrong with the linkcmds.
Does anyonesee anything wrong?
arm-rtems4.11-gcc -B../../../../../arm1136jfs/lib/ -specs bsp_specs
-qrtems -mcpu=arm1136jf-s -O2 -g -Wall -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs -mcpu=arm1136jf-s -o hello.exe
init.o ../../../../../arm1136jfs/lib/no-barrier.rel
../../../../../arm1136jfs/lib/no-dpmem.rel
../../../../../arm1136jfs/lib/no-event.rel
../../../../../arm1136jfs/lib/no-msg.rel
../../../../../arm1136jfs/lib/no-mp.rel
../../../../../arm1136jfs/lib/no-part.rel
../../../../../arm1136jfs/lib/no-region.rel
../../../../../arm1136jfs/lib/no-signal.rel
../../../../../arm1136jfs/lib/no-timer.rel
../../../../../arm1136jfs/lib/no-rtmon.rel
../../../../../arm1136jfs/lib/no-ext.rel
/opt/rtems-4.11/lib/gcc/arm-rtems4.11/4.5.1/../../../../arm-rtems4.11/bin/ld:
hello.exe section `.bss' will not fit in region `sdram'
region `sdram' overflowed by 90847 bytes
collect2: ld returned 1 exit status
gmake[5]: *** [hello.exe] Error 1
gmake[5]: Leaving directory
`/home2/work/joel/rtems-4.11-work/build/build-arm-arm1136jfs-rtems/arm-rtems4.11/c/arm1136jfs/testsuites/samples/hello
Joel Sherrill, Ph.D. Director of Research& Development
