RES: Serial device access with qemu!
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Tue Nov 23 18:12:38 UTC 2010
Jeferson,
Try to incriese the number of termio file descriptors:
#define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 6
Regards,
Wendell.
________________________________
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Jeferson Luiz Rodrigues Souza
Enviada em: terça-feira, 23 de novembro de 2010 13:25
Para: Joel Sherrill
Cc: rtems-users at rtems.org
Assunto: Re: Serial device access with qemu!
Dear Joel,
On Tue, Nov 23, 2010 at 2:21 PM, Joel Sherrill <joel.sherrill at oarcorp.com<mailto:joel.sherrill at oarcorp.com>> wrote:
On 11/23/2010 02:50 AM, Jeferson Luiz Rodrigues Souza wrote:
Hi everyone,
I am trying to access a serial port in RTEMS 4.9.4 using a pc586 bsp. However, when I execute the application using qemu the code cannot open the device, and the perror() function presents the following message: "No such file or directory". It seems that RTEMS did not initialize a properly driver to handle serial device. Is it right?
The qemu command line is:
sudo qemu -serial "/dev/ttyS0" -fda floppy.img -boot a
I made a search in this list and I found references about serial port access but nothing to help in my case. Could anyone help me or point me some documentation about serial port access in RTEMS?
The code used in the test is presented below. I do not have some experience with RTEMS and I do not know the source of this problem.
The /dev/ttyS0 above is the host serial port. The -serial says
attach attach the serial port COM1 on the target simulator
PC to the specified device. So you are attaching the virtual
COM1 to the real serial port on the host /dev/ttyS0. Is that
what you intend to do?
FWIW COM1 --> /dev/ttyS1
COM2 --> /dev/ttyS2
on the RTEMS target.
I need to read some data from a device connected in the host serial port (e.g. /dev/ttyS0) inside an application running in RTEMS with qemu. So, is my source code correct? or Do I need some extra configuration?
Where is the name of serial devices in RTEMS defined? I tried use the open() function as follows:
int serial_fp = open("/dev/ttyS0",O_RDONLY);
or
int serial_fp = open("/dev/ttyS1",O_RDONLY);
or
int serial_fp = open("COM1",O_RDONLY);
and got the same message when I checked the serial_fp value and print the error message using perror() function: "No such file or directory"
Thanks to reply,
Best regards,
Jeferson.
--joel
Thanks,
jefecomp.
#include <signal.h>
#include <pthread.h>
#include <uart.h>
#include <termios.h>
#include<sched.h>
#include <bsp.h>
#include <fcntl.h>
#include <sys/types.h>
#include <sys/stat.h>
#define CONFIGURE_INIT
void *POSIX_Init();
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATIONS_NEEDS_RTC_DRIVER
#define CONFIGURE_MICROSECONDS_PER_TICK 1000
#define CONFIGURE_MAXIMUM_POSIX_THREADS 10
#define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 10
#define CONFIGURE_MAXIMUM_POSIX_MUTEXES 10
#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 10
#define CONFIGURE_MAXIMUM_POSIX_TIMERS 10
#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 40
#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 10
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
#define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 3
#include<rtems/confdefs.h>
void *POSIX_Init()
printf("Serial Port Test!!!\n");
char buffer[255];
int bytesRead;
printf("SERIAL_FP = %i\n",serial_fp);
if(serial_fp < 0)
printf("FAILURE TO OPEN SERIAL PORT\n");
perror(serial_fp);
exit(-1);
//write(serial_fp,buffer,strlen(buffer)+1);
bytesRead = read(serial_fp, buffer, 255);
if(bytesRead < 0)
printf("Problems in the read of Serial Port");
close(serial_fp);
exit(1);
else
buffer[bytesRead] = 0;
printf(buffer);
close(serial_fp);
exit(0);
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20101123/be74bf49/attachment.html>
