Barrier question
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Nov 2 14:48:58 UTC 2010
On 11/02/2010 09:42 AM, Leon Pollak wrote:
> Hello, all.
> Using barrier, I have the following problem:
> The main task releasing the barrier when everybody have started and ready to
> work does not know the exact number of tasks to be started (and initialize the
> HW). This is because there is a configuration file, which decides which tasks
> to start, one by one.
> Releasing barrier manually also is not the best approach, as the main task
> does not know how much time does it take for each task to initialize its HW
> and be ready to start.
> So, the best solution for me would be the ability to "correct" the update the
> maximum_waiters parameter in the barrier_create call.
> But how can this be done?
Add a new directive? and supporting core service?
FWIW we are available for small tasks like this.
> Thanks.
Joel Sherrill, Ph.D. Director of Research& Development
