blackfin bf537ezlite bsp
Gedare Bloom gedare at gwmail.gwu.edu
Tue Nov 2 17:02:05 UTC 2010
On Tue, Nov 2, 2010 at 3:31 AM, Mike Frysinger <vapier.adi at gmail.com> wrote:
> On Sat, Oct 30, 2010 at 11:33, Gedare Bloom wrote:
>> I think you have the right high-level idea of what to do.  I would
>> suggest trying to build RTEMS and run it with either one of the
>> existing blackfin BSPs on the skyeye simulator
> skyeye is complete garbage.  use the gdb simulator part of the current
> Blackfin toolchain builds (you'll need 2010R1 or an svn trunk build):
> https://blackfin.uclinux.org/gf/project/toolchain/frs/
> http://docs.blackfin.uclinux.org/doku.php?id=toolchain:sim
Thanks for the info, I added these links to the RTEMS wiki (
http://www.rtems.com/wiki/index.php/Emulator ).
>> I took a look at a product sheet [5] and think that is your
>> most likely route to success, it looks to me like the 537 stamp is
>> basically an enhanced version of the 537 ezlite
> it depends on how you look at it.  they use exactly the same PCB, but
> the ezkit has some audio codecs populated on the board.  if you dont
> want that crap, then the stamp is an "enhanced" version because it's
> cheaper.
> -mike
Right. Feature creep is not necessarily an enhancement.
