Problems building RTEMS for ARM on Ubuntu 64bit
rtems at soulscythe.com rtems at soulscythe.com
Sat Nov 13 03:54:05 UTC 2010
ah, my bad. Ive found the appropriate articles in the wiki.
Quoting Ralf Corsepius <ralf.corsepius at rtems.org>:
> On 11/12/2010 06:44 PM, rtems at soulscythe.com wrote:
>> I've removed all of the prebuild binaries and downloaded and recompiled
>> a newer toolchain using this script
>> https://github.com/esden/summon-arm-toolchain
> This will not work - This toolchain is not suiteable for RTEMS.
> Your initial report indicates your Ubunty installation contains a
> libgmp which incompatible to CentOS5's, even though Ubunty's libgmp.3
> and CentOS5's carry the same SONAME.
> => Either Ubunty or CentOS's libgmp is broken.
> Ralf
