RES: Serial device access with qemu!
Jeferson Luiz Rodrigues Souza
jeferodrigues at gmail.com
Wed Nov 24 08:58:38 UTC 2010
Dear Joel and Wendell,
Thank you for your help. I applied all procedures provided and now I can
read/write to/from host serial port.
Best regards,
Jeferson.
On Tue, Nov 23, 2010 at 6:32 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> Hi,
> I have attached a diff to 4.9 which will make the pc386 install
> tty_drv.h. There is also a diff to the fileio sample to show
> the configuration changes. Plus a png to show that the
> serial devices are there.
> Hopefully this will help.
> --joel
> On 11/23/2010 12:12 PM, Wendell Pereira da Silva wrote:
>> Jeferson,
>> Try to incriese the number of termio file descriptors:
>> #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 6
>> Regards,
>> Wendell.
>> *De:*rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
>> *Em nome de *Jeferson Luiz Rodrigues Souza
>> *Enviada em:* terça-feira, 23 de novembro de 2010 13:25
>> *Para:* Joel Sherrill
>> *Cc:* rtems-users at rtems.org
>> *Assunto:* Re: Serial device access with qemu!
>> Dear Joel,
>> On Tue, Nov 23, 2010 at 2:21 PM, Joel Sherrill <joel.sherrill at oarcorp.com<mailto:
>> joel.sherrill at oarcorp.com>> wrote:
>> On 11/23/2010 02:50 AM, Jeferson Luiz Rodrigues Souza wrote:
>> Hi everyone,
>> I am trying to access a serial port in RTEMS 4.9.4 using a pc586 bsp.
>> However, when I execute the application using qemu the code cannot open the
>> device, and the perror() function presents the following message: "No such
>> file or directory". It seems that RTEMS did not initialize a properly driver
>> to handle serial device. Is it right?
>> The qemu command line is:
>> sudo qemu -serial "/dev/ttyS0" -fda floppy.img -boot a
>> I made a search in this list and I found references about serial port
>> access but nothing to help in my case. Could anyone help me or point me some
>> documentation about serial port access in RTEMS?
>> The code used in the test is presented below. I do not have some
>> experience with RTEMS and I do not know the source of this problem.
>> The /dev/ttyS0 above is the host serial port. The -serial says
>> attach attach the serial port COM1 on the target simulator
>> PC to the specified device. So you are attaching the virtual
>> COM1 to the real serial port on the host /dev/ttyS0. Is that
>> what you intend to do?
>> FWIW COM1 --> /dev/ttyS1
>> COM2 --> /dev/ttyS2
>> on the RTEMS target.
>> I need to read some data from a device connected in the host serial port
>> (e.g. /dev/ttyS0) inside an application running in RTEMS with qemu. So, is
>> my source code correct? or Do I need some extra configuration?
>> Where is the name of serial devices in RTEMS defined? I tried use the
>> open() function as follows:
>> int serial_fp = open("/dev/ttyS0",O_RDONLY);
>> or
>> int serial_fp = open("/dev/ttyS1",O_RDONLY);
>> or
>> int serial_fp = open("COM1",O_RDONLY);
>> and got the same message when I checked the serial_fp value and print the
>> error message using perror() function: "No such file or directory"
>> Thanks to reply,
>> Best regards,
>> Jeferson.
>> --joel
>> Thanks,
>> jefecomp.
>> #include <signal.h>
>> #include <stdlib.h>
>> #include <stdio.h>
>> #include <pthread.h>
>> #include <uart.h>
>> #include <termios.h>
>> #include<sched.h>
>> #include <bsp.h>
>> #include <fcntl.h>
>> #include <sys/types.h>
>> #include <sys/stat.h>
>> #define CONFIGURE_INIT
>> #include <rtems.h>
>> void *POSIX_Init();
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> #define CONFIGURE_APPLICATIONS_NEEDS_RTC_DRIVER
>> #define CONFIGURE_MICROSECONDS_PER_TICK 1000
>> #define CONFIGURE_MAXIMUM_POSIX_THREADS 10
>> #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 10
>> #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 10
>> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 10
>> #define CONFIGURE_MAXIMUM_POSIX_TIMERS 10
>> #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 40
>> #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 10
>> #define CONFIGURE_POSIX_INIT_THREAD_TABLE
>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
>> #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 3
>> #include<rtems/confdefs.h>
>> void *POSIX_Init()
>> printf("Serial Port Test!!!\n");
>> char buffer[255];
>> int bytesRead;
>> printf("SERIAL_FP = %i\n",serial_fp);
>> if(serial_fp < 0)
>> printf("FAILURE TO OPEN SERIAL PORT\n");
>> perror(serial_fp);
>> exit(-1);
>> //write(serial_fp,buffer,strlen(buffer)+1);
>> bytesRead = read(serial_fp, buffer, 255);
>> if(bytesRead < 0)
>> printf("Problems in the read of Serial Port");
>> close(serial_fp);
>> exit(1);
>> else
>> buffer[bytesRead] = 0;
>> printf(buffer);
>> close(serial_fp);
>> exit(0);
>> -- Joel Sherrill, Ph.D. Director of Research&
>> Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
> Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20101124/034097df/attachment-0001.html>
