RTEMS/LM32 interrupt handling
Sébastien Bourdeauducq sebastien at milkymist.org
Fri Oct 15 18:08:52 UTC 2010
Hi,
I have converted the LM32 CPU target to use the new RTEMS interrupt API
(based on rtems_interrupt_catch/bsp_interrupt_vector_xxx):
http://github.com/fallen/rtems-milkymist/commit/2b3f1cfb97cb122c94def972f68cdba34746fdac
The set_vector API you had implemented is deprecated.
It works with the Milkymist target, but it has broken your LM32 EVR
target. Could you either:
* send me a patch against my tree that fixes the EVR (I am planning to
  merge the whole thing in the official RTEMS later on)
* patch the RTEMS tree to use the new API with LM32 (so my tree can
  later be merged into RTEMS without breaking EVR)
Thanks,
S.
