Problems with IDE Eclipse + RTEMS CDT Plug-in
Mon Oct 18 11:24:23 UTC 2010
On 10/18/2010 01:19 PM, Евгений Савенко wrote:
> Hello, all.
> I have been learning the RTEMS and faced with first problem.  I
> installed the plug-in and setup settings “Base path” and “BSP path” in
> Window > Preferences > C/C++ > RTEMS, after I created new “C” project
> and either setup settings “Base path” and “BSP path” in Project >
> Properties > C/C++ Build > RTEMS.  Project doesn't compiled because
> the Eclipse using the RTEMS-C-Compiler “/opt/rtems-4.8/bin/gcc” but
> real the compiler for my platform is
> “/opt/rtems-4.8/bin/<arch>-rtems4.8-gcc” and I can’t change this
> setting,  however as the other settings: RTEMS-Linker, RTEMS-Assembler
> etc.
Do you have the BSP installed? Can you build applications without Eclipse?
> I change field “Command” in  Project > Properties > C/C++ Build >
> Settings > RTEMS-C-Compiler and press OK but “Command” doesn't change.
>  I temporarily solved this problem by renaming the file
> “<arch>--rtems4.8-gcc” on the “gcc”
You cannot change the values in this dialog.
> I have tried Eclipse 3.5 and last release 3.6 and the same effect.
> I use Linux Debian/lenny as a development platform and the RTEMS release 4.8.
> Installation of pre-build tools and build of RTEMS completed succsesfully.
> Thanks for any help.
> Best regards,
> Eugene Savenko.
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
