Running the Bootstrap Script under MinGW
Sam Lost
slostuk at gmail.com
Fri Oct 22 04:45:06 UTC 2010
I have extracted the RTEMS 4.10 Label from CVS as detailed:
http://www.rtems.com/wiki/index.php/RTEMS_CVS_Repository
I am now attempting to run the bootstrap script:
http://www.rtems.com/wiki/index.php/Quick_Start
However I receive the following errors:
./c
./c/src/ada-tests
is already registered with AC_CONFIG_FILES.
../../lib/autoconf/status.m4:290: AC_CONFIG_FILESis expanded from...
configure.ac:57: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
aclocal: autom4te failed with exit status:1
automake: autoconf failed with exit status: 1
Any ideas?
Regards
Sam
URL: <http://lists.rtems.org/pipermail/users/attachments/20101022/ff0f558b/attachment.html>
