problems with printfs inside rtems_timer_server_fire_after() callback
Thu Oct 7 09:33:51 UTC 2010
Hi,
which version of RTEMS do you use?  The timer server was quite broken before
2009-11-30.  See also
http://www.rtems.org/pipermail/rtems-users/2009-November/006248.html
Have a nice day!
On 10/07/2010 11:24 AM, Aitor Viana wrote:
> Hi all,
> I am getting _Internal_error_Occurred from rtems_semaphore_obtain function.
> I back-traced the error and it appears when the callback register
> with  rtems_timer_server_fire_after() calls printf() function. Removing
> the printf's solve the problem.
> Reading at the RTEMS manual I understand that by using timer servers
> should be possible to perform operations that you would in a normal
> RTEMS task. Is that so?
> Thanks,
> aitor
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
