problems with printfs inside rtems_timer_server_fire_after() callback
Aitor Viana
aitor.viana.sanchez at esa.int
Thu Oct 7 09:24:51 UTC 2010
Hi all,
I am getting _Internal_error_Occurred from rtems_semaphore_obtain function.
I back-traced the error and it appears when the callback register
with rtems_timer_server_fire_after() calls printf() function. Removing the
printf's solve the problem.
Reading at the RTEMS manual I understand that by using timer servers should
be possible to perform operations that you would in a normal RTEMS task. Is
that so?
Thanks,
aitor
URL: <http://lists.rtems.org/pipermail/users/attachments/20101007/4e29490e/attachment.html>
