NTP
Daron Chabot daron.chabot at gmail.com
Wed Oct 13 14:06:21 UTC 2010
On Wed, Oct 13, 2010 at 8:27 AM, Martin Grim <W.M.Grim at sron.nl> wrote:
> > Can you send me your NTP server config (/etc/ntp.conf) and
> > your target's network config?
> Below my configuration for BSD:
> #define DEFAULT_IP_ADDR     "192.168.0.80"
> #define DEFAULT_IP_NETMASK  "255.255.255.0"
> #define DEFAULT_IP_GATEWAY  "192.168.0.1"
> #define DEFAULT_TCP_PORT    5001
> #define DEFAULT_NTP_SERVER  "172.16.150.35"
> // 172.16.150.25 is the SRON NTP server
As I understand things here, your target ("leon") is directly connected to
your linux box? And, this linux box has (at least) two network interfaces,
on 192.168.0.xx and 172.16.xx.xx ?
Unless you are doing NAT on the linux box between the 192.168 and 172.16
networks, I don't see how "leon" could reach the 172.16.xx.xx subnet.
You could change DEFAULT_NTP_SERVER to 192.168.0.1 on your target, and add
the following to your ntp.conf (then restart the NTP daemon):
   restrict 192.168.0.80 mask 255.255.255.0 nomodify notrap
-- dc
> // Ethernet
> static struct rtems_bsdnet_ifconfig gNetdriverConfig = {
>    (char*)RTEMS_BSP_NETWORK_DRIVER_NAME,   // name
>    RTEMS_BSP_NETWORK_DRIVER_ATTACH,        // attach
>    NULL,
>    (char *)DEFAULT_IP_ADDR,        // ip_address
>    (char *)DEFAULT_IP_NETMASK,     // ip_netmask
> // Network configuration
> struct rtems_bsdnet_config rtems_bsdnet_config = {
>    &gNetdriverConfig,              // ifconfig
>    NULL,                           // bootp
>    THREAD_NORMAL_PRIO,             // network_task_priority
>    128*1024,                       // mbuf_bytecount */
>    256*1024,                       // mbuf_cluster_bytecount */
>    (char *)"leon",                 // hostname
>    (char *)"localnet",             // domainname
>    (char *)DEFAULT_IP_GATEWAY,     // gateway
>    NULL,                           // log host
>    {NULL, },                       // Name server(s)
>    { (char*)DEFAULT_NTP_SERVER, },
> My target is connected to a Linux PC with the following in /etc/ntp.conf.
> To keep things a bit short, I removed all comments form ntp.conf.
> driftfile /var/lib/ntp/ntp.drift
> statsdir /var/log/ntpstats/
> statistics loopstats peerstats clockstats
> filegen loopstats file loopstats type day enable
> filegen peerstats file peerstats type day enable
> filegen clockstats file clockstats type day enable
> server ntp.sron.nl
> server 127.127.1.0
> fudge 127.127.1.0 stratum 13
> restrict default kod notrap nomodify nopeer noquery
> restrict 127.0.0.1 nomodify
> Any help on my misconfiguration is greatly appriciated!
> Regards,
> Martin
> ir. W.M. Grim
> SRON Netherlands Institute for Space Research
> Sorbonnelaan 2
> 3584 CA Utrecht, The Netherlands
> www.sron.nl
URL: <http://lists.rtems.org/pipermail/users/attachments/20101013/9225da6f/attachment-0001.html>
