NTP
Martin Grim
W.M.Grim at sron.nl
Wed Oct 13 12:27:19 UTC 2010
> Can you send me your NTP server config (/etc/ntp.conf) and
> your target's network config?
Below my configuration for BSD:
#define DEFAULT_IP_ADDR "192.168.0.80"
#define DEFAULT_IP_NETMASK "255.255.255.0"
#define DEFAULT_IP_GATEWAY "192.168.0.1"
#define DEFAULT_TCP_PORT 5001
#define DEFAULT_NTP_SERVER "172.16.150.35"
// 172.16.150.25 is the SRON NTP server
// Ethernet
static struct rtems_bsdnet_ifconfig gNetdriverConfig = {
(char*)RTEMS_BSP_NETWORK_DRIVER_NAME, // name
RTEMS_BSP_NETWORK_DRIVER_ATTACH, // attach
NULL,
(char *)DEFAULT_IP_ADDR, // ip_address
(char *)DEFAULT_IP_NETMASK, // ip_netmask
// Network configuration
struct rtems_bsdnet_config rtems_bsdnet_config = {
&gNetdriverConfig, // ifconfig
NULL, // bootp
THREAD_NORMAL_PRIO, // network_task_priority
128*1024, // mbuf_bytecount */
256*1024, // mbuf_cluster_bytecount */
(char *)"leon", // hostname
(char *)"localnet", // domainname
(char *)DEFAULT_IP_GATEWAY, // gateway
NULL, // log host
{NULL, }, // Name server(s)
{ (char*)DEFAULT_NTP_SERVER, },
My target is connected to a Linux PC with the following in /etc/ntp.conf. To keep things a bit short, I removed all comments form ntp.conf.
driftfile /var/lib/ntp/ntp.drift
statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
server ntp.sron.nl
server 127.127.1.0
fudge 127.127.1.0 stratum 13
restrict default kod notrap nomodify nopeer noquery
restrict 127.0.0.1 nomodify
Any help on my misconfiguration is greatly appriciated!
Regards,
Martin
ir. W.M. Grim
SRON Netherlands Institute for Space Research
Sorbonnelaan 2
3584 CA Utrecht, The Netherlands
www.sron.nl
