Yet more MinGW Build Issues
Chris Johns
chrisj at rtems.org
Thu Oct 21 09:15:24 UTC 2010
On 21/10/10 12:24 AM, Sam Lost wrote:
> I would be happy to use 4.10 however, the link given in the following
> document is incorrect:
Ok lets work on 4.10.
> http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00054.html
That could be true. Things have changed and the documentation has not
been updated. MinGW is changing the way you use it so lets work with the
latest and get it into the list archive.
Head over to http://sourceforge.net/projects/mingw/files/.
Download mingw-get-inst-20100813.exe and run. I selected the C++ and
MSYS Base System option in the "Select Components" section. You may need
to scroll down to find "MSYS Basic System". It will open a cmd.exe box
and then download most of the needed bits.
A missing package not downloaded is perl. Open the MSYS link on the
MinGW file page and look for the latest perl version and download the
bin lzma file. Open a MSYS shell. It is under "C:\MinGW\msys\1.0".
Enter these commands:
$ cd /c/MinGW/msys/1.0
$ cat ~/My\
Documents/Downloads/perl-5.6.1_2-2-msys-1.0.13-bin.tar.lzma | lzma -d |
tar xvf -
Now edit "/etc/fstab" to have:
$ cat /etc/fstab
C:\MinGW\ /mingw
c:\opt\ /opt
Note, this is c:\MinGW\msys\1.0\etc\fstab. It also assumes you have a
directory c:\opt. If not please add.
Now download the prebuild tar files from the RTEMS ftp users (or a
mirror) found here:
http://www.rtems.org/ftp/pub/rtems/mingw32/4.10/
I will download the PowerPC target. The list is:
rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.tar.bz2
rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2
rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.bz2
rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.tar.bz2
rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-2.tar.bz2
rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar.bz2
To installed, in the MSYS shell enter:
$ cd /c
$ cat ~/My\
Documents/Downloads/rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.tar.bz2
| bzip2 -d | tar xvf -
$ cat ~/My\
Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2 |
$ cat ~/My\
Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.bz2
$ cat ~/My\
Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.tar.bz2
$ cat ~/My\
Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-2.tar.bz2
$ cat ~/My\
Documents/Downloads/rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar.bz2 |
You also need to install the autoconf and automake packages.
$ cd /c
$ cat ~/My\ Documents/Downloads/rtems-4.10-autoconf-2.68-1.tar.bz2 |
$ cat ~/My\ Documents/Downloads/rtems-4.10-automake-1.11.1-2.tar.bz2 |
Update your path and you should be able to build RTEMS from the 4.10 branch.
If you get a zlib dll error look in the MinGW bin directory for a zlib
dll and copy it to the name the RTEMS tools reports. I will update this
thread with that info when I see it.
