Yet more MinGW Build Issues
Sam Lost slostuk at gmail.com
Thu Oct 21 11:06:38 UTC 2010
Many Thanks for your help this morning, I am having some trouble locating
the following file
rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar.bz2
Where might a locate this file.
Regards
William
On Thu, Oct 21, 2010 at 10:15 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 21/10/10 12:24 AM, Sam Lost wrote:
>> I would be happy to use 4.10 however, the link given in the following
>> document is incorrect:
> Ok lets work on 4.10.
>> http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00054.html
> That could be true. Things have changed and the documentation has not been
> updated. MinGW is changing the way you use it so lets work with the latest
> and get it into the list archive.
> Head over to http://sourceforge.net/projects/mingw/files/.
> Download mingw-get-inst-20100813.exe and run. I selected the C++ and MSYS
> Base System option in the "Select Components" section. You may need to
> scroll down to find "MSYS Basic System". It will open a cmd.exe box and then
> download most of the needed bits.
> A missing package not downloaded is perl. Open the MSYS link on the MinGW
> file page and look for the latest perl version and download the bin lzma
> file. Open a MSYS shell. It is under "C:\MinGW\msys\1.0".
> Enter these commands:
>  $ cd /c/MinGW/msys/1.0
>  $ cat ~/My\ Documents/Downloads/perl-5.6.1_2-2-msys-1.0.13-bin.tar.lzma |
> lzma -d | tar xvf -
> Now edit "/etc/fstab" to have:
>  $ cat /etc/fstab
>  C:\MinGW\   /mingw
>  c:\opt\     /opt
> Note, this is c:\MinGW\msys\1.0\etc\fstab. It also assumes you have a
> directory c:\opt. If not please add.
> Now download the prebuild tar files from the RTEMS ftp users (or a mirror)
> found here:
>  http://www.rtems.org/ftp/pub/rtems/mingw32/4.10/
> I will download the PowerPC target. The list is:
>  rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.tar.bz2
>  rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2
>  rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.bz2
>  rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.tar.bz2
>  rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-2.tar.bz2
> To installed, in the MSYS shell enter:
>  $ cd /c
>  $ cat ~/My\
> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.tar.bz2 |
> bzip2 -d | tar xvf -
>  $ cat ~/My\
> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2 | bzip2
> -d | tar xvf -
>  $ cat ~/My\
> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.bz2 |
>  $ cat ~/My\
> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.tar.bz2
>  $ cat ~/My\
> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-2.tar.bz2
>  $ cat ~/My\
> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar.bz2 |
> You also need to install the autoconf and automake packages.
>  $ cd /c
>  $ cat ~/My\ Documents/Downloads/rtems-4.10-autoconf-2.68-1.tar.bz2 | bzip2
> -d | tar xvf -
>  $ cat ~/My\ Documents/Downloads/rtems-4.10-automake-1.11.1-2.tar.bz2 |
> Update your path and you should be able to build RTEMS from the 4.10
> branch.
> If you get a zlib dll error look in the MinGW bin directory for a zlib dll
> and copy it to the name the RTEMS tools reports. I will update this thread
> with that info when I see it.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/581056dd/attachment-0001.html>
