Yet more MinGW Build Issues
Sam Lost slostuk at gmail.com
Thu Oct 21 12:45:44 UTC 2010
Many Thanks, now for the next road block, I have download 4.10 from CVS. I
run the boot strap srcipt, and I get the following error.
autom4te: /usr/bin/mr failed with exit status: 1
If I run m4 --version the following is returned
m4 (GNU M4) 1.4.14
I also had to source the msys-crypt-0.dll.
Regards
Sam W
On Thu, Oct 21, 2010 at 12:43 PM, Daron Chabot <daron.chabot at gmail.com>wrote:
> It's cleverly hidden amongst the gcc tarballs:
> http://www.rtems.org/ftp/pub/rtems/mingw32/4.10/rtems-4.10-powerpc-rtems4.10-gcc/rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar.bz2
>   On Thu, Oct 21, 2010 at 7:06 AM, Sam Lost <slostuk at gmail.com> wrote:
>>   Many Thanks for your help this morning, I am having some trouble
>> locating the following file
>> Where might a locate this file.
>> Regards
>> William
>> On Thu, Oct 21, 2010 at 10:15 AM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 21/10/10 12:24 AM, Sam Lost wrote:
>>>> I would be happy to use 4.10 however, the link given in the following
>>>> document is incorrect:
>>> Ok lets work on 4.10.
>>>> http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00054.html
>>> That could be true. Things have changed and the documentation has not
>>> been updated. MinGW is changing the way you use it so lets work with the
>>> latest and get it into the list archive.
>>> Head over to http://sourceforge.net/projects/mingw/files/.
>>> Download mingw-get-inst-20100813.exe and run. I selected the C++ and MSYS
>>> Base System option in the "Select Components" section. You may need to
>>> scroll down to find "MSYS Basic System". It will open a cmd.exe box and then
>>> download most of the needed bits.
>>> A missing package not downloaded is perl. Open the MSYS link on the MinGW
>>> file page and look for the latest perl version and download the bin lzma
>>> file. Open a MSYS shell. It is under "C:\MinGW\msys\1.0".
>>> Enter these commands:
>>>  $ cd /c/MinGW/msys/1.0
>>>  $ cat ~/My\ Documents/Downloads/perl-5.6.1_2-2-msys-1.0.13-bin.tar.lzma
>>> | lzma -d | tar xvf -
>>> Now edit "/etc/fstab" to have:
>>>  $ cat /etc/fstab
>>>  C:\MinGW\   /mingw
>>>  c:\opt\     /opt
>>> Note, this is c:\MinGW\msys\1.0\etc\fstab. It also assumes you have a
>>> directory c:\opt. If not please add.
>>> Now download the prebuild tar files from the RTEMS ftp users (or a
>>> mirror) found here:
>>> I will download the PowerPC target. The list is:
>>>  rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.tar.bz2
>>>  rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2
>>>  rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.bz2
>>>  rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.tar.bz2
>>>  rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-2.tar.bz2
>>> To installed, in the MSYS shell enter:
>>>  $ cd /c
>>>  $ cat ~/My\
>>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.tar.bz2 |
>>> bzip2 -d | tar xvf -
>>>  $ cat ~/My\
>>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2 | bzip2
>>> -d | tar xvf -
>>>  $ cat ~/My\
>>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.bz2 |
>>>  $ cat ~/My\
>>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.tar.bz2
>>>  $ cat ~/My\
>>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-2.tar.bz2
>>>  $ cat ~/My\
>>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar.bz2 |
>>> You also need to install the autoconf and automake packages.
>>>  $ cd /c
>>>  $ cat ~/My\ Documents/Downloads/rtems-4.10-autoconf-2.68-1.tar.bz2 |
>>>  $ cat ~/My\ Documents/Downloads/rtems-4.10-automake-1.11.1-2.tar.bz2 |
>>> Update your path and you should be able to build RTEMS from the 4.10
>>> branch.
>>> If you get a zlib dll error look in the MinGW bin directory for a zlib
>>> dll and copy it to the name the RTEMS tools reports. I will update this
>>> thread with that info when I see it.
>>> Chris
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/118cd512/attachment-0001.html>
