Yet more MinGW Build Issues
    Daron Chabot
    daron.chabot at gmail.com
    Thu Oct 21 11:43:34 UTC 2010
It's cleverly hidden amongst the gcc tarballs:
http://www.rtems.org/ftp/pub/rtems/mingw32/4.10/rtems-4.10-powerpc-rtems4.10-gcc/rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar.bz2
On Thu, Oct 21, 2010 at 7:06 AM, Sam Lost <slostuk at gmail.com> wrote:
> Many Thanks for your help this morning, I am having some trouble locating
> the following file
> Where might a locate this file.
> Regards
> William
> On Thu, Oct 21, 2010 at 10:15 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 21/10/10 12:24 AM, Sam Lost wrote:
>>> I would be happy to use 4.10 however, the link given in the following
>>> document is incorrect:
>> Ok lets work on 4.10.
>>> http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00054.html
>> That could be true. Things have changed and the documentation has not been
>> updated. MinGW is changing the way you use it so lets work with the latest
>> and get it into the list archive.
>> Head over to http://sourceforge.net/projects/mingw/files/.
>> Download mingw-get-inst-20100813.exe and run. I selected the C++ and MSYS
>> Base System option in the "Select Components" section. You may need to
>> scroll down to find "MSYS Basic System". It will open a cmd.exe box and then
>> download most of the needed bits.
>> A missing package not downloaded is perl. Open the MSYS link on the MinGW
>> file page and look for the latest perl version and download the bin lzma
>> file. Open a MSYS shell. It is under "C:\MinGW\msys\1.0".
>> Enter these commands:
>>  $ cd /c/MinGW/msys/1.0
>>  $ cat ~/My\ Documents/Downloads/perl-5.6.1_2-2-msys-1.0.13-bin.tar.lzma |
>> lzma -d | tar xvf -
>> Now edit "/etc/fstab" to have:
>>  $ cat /etc/fstab
>>  C:\MinGW\   /mingw
>>  c:\opt\     /opt
>> Note, this is c:\MinGW\msys\1.0\etc\fstab. It also assumes you have a
>> directory c:\opt. If not please add.
>> Now download the prebuild tar files from the RTEMS ftp users (or a mirror)
>> found here:
>> I will download the PowerPC target. The list is:
>>  rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.tar.bz2
>>  rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2
>>  rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.bz2
>>  rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.tar.bz2
>>  rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-2.tar.bz2
>> To installed, in the MSYS shell enter:
>>  $ cd /c
>>  $ cat ~/My\
>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.tar.bz2 |
>> bzip2 -d | tar xvf -
>>  $ cat ~/My\
>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2 | bzip2
>> -d | tar xvf -
>>  $ cat ~/My\
>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.bz2 |
>>  $ cat ~/My\
>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.tar.bz2
>>  $ cat ~/My\
>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-2.tar.bz2
>>  $ cat ~/My\
>> Documents/Downloads/rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar.bz2 |
>> You also need to install the autoconf and automake packages.
>>  $ cd /c
>>  $ cat ~/My\ Documents/Downloads/rtems-4.10-autoconf-2.68-1.tar.bz2 |
>>  $ cat ~/My\ Documents/Downloads/rtems-4.10-automake-1.11.1-2.tar.bz2 |
>> Update your path and you should be able to build RTEMS from the 4.10
>> branch.
>> If you get a zlib dll error look in the MinGW bin directory for a zlib dll
>> and copy it to the name the RTEMS tools reports. I will update this thread
>> with that info when I see it.
>> Chris
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20101021/2c564e06/attachment-0001.html>
