Running the Bootstrap Script under MinGW
Fri Oct 22 13:44:05 UTC 2010
I would delete everything and follow the steps from Chris Johns.  Btw. which
Windows version do you use?
On 10/22/2010 03:36 PM, Sam Lost wrote:
> Sebastian provided a copy of M4 1.4.7 after installing M4 1.4.7 I now
> get the following error
> /usr/bin/m4: unrecongized option --gnu
> Any ideas I have been battl;ing trying to build either 4.9 or 4.10 under
> windows for a while now :-(
> Regards
> Sam
> On Fri, Oct 22, 2010 at 5:45 AM, Sam Lost <slostuk at gmail.com
> <mailto:slostuk at gmail.com>> wrote:
>     I have extracted the RTEMS 4.10 Label from CVS as detailed:
>     http://www.rtems.com/wiki/index.php/RTEMS_CVS_Repository
>     I am now attempting to run the bootstrap script:
>     http://www.rtems.com/wiki/index.php/Quick_Start
>     However I receive the following errors:
>     ./c
>     ./c/src/ada-tests
>      is already registered with AC_CONFIG_FILES.
>     ../../lib/autoconf/status.m4:290: AC_CONFIG_FILESis expanded from...
>     configure.ac:57 <http://configure.ac:57/>: the top level
>     autom4te: /usr/bin/m4 failed with exit status: 1
>     aclocal: autom4te failed with exit status:1
>     automake: autoconf failed with exit status: 1
>     Any ideas?
>     Regards
>     Sam
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
