Problem with building powerpc-rtems4.11-gcc
Gedare Bloom
gedare at gwmail.gwu.edu
Thu Sep 9 14:55:20 UTC 2010
Also, the 4.1.x series of GCC can be a little bit wonky (technical term)
when compiling system tools. Otherwise, since the problem is in assembler,
I would suspect the binutils.
-Gedare
On Thu, Sep 9, 2010 at 10:41 AM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> On 09/09/2010 09:16 AM, Steven Grunza wrote:
>> -----Original Message-----
>>> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
>>> Sent: Thursday, September 09, 2010 10:03 AM
>>> To: Steven Grunza
>>> Cc: rtems-users at rtems.org
>>> Subject: Re: Problem with building powerpc-rtems4.11-gcc
>>> On 09/09/2010 08:55 AM, Steven Grunza wrote:
>>>> I'm currently changing build machines from a single CPU CentOS4
>>> box to a
>>>> Core2Quad CentOS5 box. Part of the change is the new machine has
>>> GCC
>>>> 4.1.2 instead of 3.4.6. The new machine is also running 64-bit
>>> (a first
>>>> for me) instead of 32-bit.
>>>> Binutils 2.20.1 built and installed ok but gcc 4.5.1 is giving me
>>> a
>>>> strange error; it looks like the native compiler can't compile
>>> the
>>>> source to gcc-4.5.1:
>>> What is your PATH when building gcc? I have a hunch that
>>> you forgot to put the RTEMS cross-assembler at the head
>>> of your PATH. It is likely using the native as which won't
>>> work for powerpc code. :)
>> Actually, it should be the native GCC since I'm building the
>> cross-compiler.
> I didn't notice this was on a native gcc. Still probably
> worth it to repeat the command by hand with a -v and see
> if what as it is using. Worse case, you might have an old
> binutils.
> Upon review of my path; however, I noticed something I consider a
>> security error: my path had . in it.
> It has long been considered a security mistake. I think this
> dates back to the earliest UNIX days. :)
> grunzasr at c2q% echo $PATH
>> /opt/rtems4.11/bin:.:/usr/local/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/l
>> ocal/sbin:/usr/X11R6/bin
>> I removed the . and then the build got past the problem (won't know if
>> it worked until it finishes building).
>> I consider the . in my PATH as a security error since it allows a
>> someone to drop an executable (like vi) in a source directory and when
>> the victim enters the command "vi foo.c" the victim runs the vi
>> executable from the current directory instead of from /usr/bin or
>> wherever it should be.
>> I'm not sure why having the . in my path caused a problem but I don't
>> mind removing it so I guess the problem is solved.
>>> make[2]: Entering directory
>>>> `/home/grunzasr/rtems_head/tools/b-gcc-ppc/gcc'
>>>> gcc -c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -W -Wall
>>>> -Wwrite-strings -Wcast-qual -Wstrict-prototypes -Wmissing-
>>> prototypes
>>>> -Wmissing-format-attribute -Wold-style-definition -Wc++-compat
>>>> -DHAVE_CONFIG_H -DGENERATOR_FILE -I. -Ibuild -I../../gcc-
>>> 4.5.1/gcc
>>>> -I../../gcc-4.5.1/gcc/build -I../../gcc-4.5.1/gcc/../include
>>>> -I../../gcc-4.5.1/gcc/../libcpp/include
>>>> -I../../gcc-4.5.1/gcc/../libdecnumber
>>>> -I../../gcc-4.5.1/gcc/../libdecnumber/dpd -I../libdecnumber
>>> \^M
>>>> -o build/genmodes.o ../../gcc-
>>> 4.5.1/gcc/genmodes.c^M
>>>> /tmp/cc4psLZx.s: Assembler messages:^M
>>>> /tmp/cc4psLZx.s:18: Error: Unrecognized opcode: `movq'^M
>>>> /tmp/cc4psLZx.s:21: Error: Unrecognized opcode: `movq'^M
>>>> My various tools are:
>>>> grunzasr at c2q% gcc --version
>>>> gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-48)
>>>> grunzasr at c2q% autoconf --version
>>>> autoconf (GNU Autoconf) 2.67
>>>> grunzasr at c2q% automake --version
>>>> automake (GNU automake) 1.11.1
>>>> grunzasr at c2q% m4 --version
>>>> m4 (GNU M4) 1.4.14
>>>> autoconf-2.67
>>>> automake-1.11.1
>>>> binutils-2.20.1
>>>> gcc-4.5.1
>>>> gmp-5.0.1
>>>> m4-1.4.14
>>>> mpc-0.8.1
>>>> mpfr-2.4.2
>>>> newlib-1.18.0
>>>> I configured the b-gcc-ppc directory with the following:
>>>> ../gcc-4.5.1/configure --prefix=/opt/rtems4.11
>>>> --target=powerpc-rtems4.11 --with-gnu-as --with-gnu-ld --with-
>>> newlib
>>>> --verbose --enable-threads --enable-languages="c,c++"
>>>> If this didn't build ok on the CentOS4-32bit machine I would just
>>> assume
>>>> user error but I've run out of things to check. Any suggestions
>>> on
>>>> what's wrong or where to look?
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20100909/97748bb4/attachment-0001.html>
