Problem with building powerpc-rtems4.11-gcc
Ralf Corsepius
ralf.corsepius at rtems.org
Thu Sep 9 15:02:14 UTC 2010
On 09/09/2010 04:55 PM, Gedare Bloom wrote:
> Also, the 4.1.x series of GCC can be a little bit wonky (technical term)
> when compiling system tools.
No idea what makes you say this. CentOS5's host compiler is amongst the
most stable and reliable GCC's around.
> Otherwise, since the problem is in assembler,
> I would suspect the binutils.
Well, ... in most cases, the origin of such issues sits between keyboard
and CRT (rsp. LCD). Building cross-compilers isn't trivial and is even
less trival on aging OSes.
Ralf
