RTEMS 4.10 Autoconf tools
Ian Caddy
ianc at goanna.iinet.net.au
Fri Sep 10 02:30:07 UTC 2010
On 10/09/2010 10:20 AM, Chris Johns wrote:
> On 10/09/10 11:45 AM, Ian Caddy wrote:
>> On 9/09/2010 4:39 PM, Ralf Corsepius wrote:
>>> ftp://ftp.rtems.org/pub/rtems/mingw32/4.10/rtems-4.10-autoconf/
>>> ftp://ftp.rtems.org/pub/rtems/mingw32/4.10/rtems-4.10-automake/
>> Thanks that was the simple solution I was looking for, but Sebastian's
>> solution also worked, I got caught up in trying to find a pre-built
>> autotools for Mingw, but they built straight out of the source for me as
>> well.
> I recommend you use the tools built by Ralf for a couple of reasons.
> They may contain patches and we hope you report issues so we can fix them.
I might have spoken too soon about everything being OK. The bootstrap
and configure worked OK with the autotools I built, but the compile
failed somewhere in pthreads.
I decided to use Ralf's prebuilt autotools, so I put them into my tools
directory in /opt/rtems-4.10/bin
but after a ./bootstrap -c,
then ./bootstrap
It failed to find automake ( it was picking up the older RTEMS-4.7
automake).
I then looked and there looked like a link file from automake-1.11 to
automake, but I don't think lnk files work in msys.
I have copied automake-1.11 over to automake, and the same for
aclocal-1.11 to aclocal.
This seems to have sorted the bootstrap out, now onto the configure and
make...
I will let you know if I have any more issues.
regards,
Ian C.
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9444 2634
