RTEMS 4.10 Autoconf tools
Ian Caddy
ianc at goanna.iinet.net.au
Fri Sep 10 03:30:05 UTC 2010
On 10/09/2010 10:30 AM, Ian Caddy wrote:
> This seems to have sorted the bootstrap out, now onto the configure and
> make...
> I will let you know if I have any more issues.
OK, it turns out the built myself autotools were not the problem, I
still have a compile fail at cpulit/posix/src/pthread.c
Error below:
arm-rtems4.10-gcc --pipe -DHAVE_CONFIG_H -I..
-I../../cpukit/../../../at91sam9263ek/lib/include -D__RTEMS_INSIDE__
-Werror=overflow -Werror=pointer-to-int-cast -Werror=int-to-pointer-cast
-mstructure-size-boundary=8 -mcpu=arm926ej-s -mfpu=vfp -mfloat-abi=soft
-g -Wall -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -MT src/libposix_a-pthread.o -MD -MP -MF
src/.deps/libposix_a-pthread.Tpo -c -o src/libposix_a-pthread.o `test -f
'src/pthread.c' || echo
'/c/rtems-4.10/c/src/../../cpukit/posix/'`src/pthread.c
c:/rtems-4.10/cpukit/posix/src/pthread.c: In function
'_POSIX_Threads_Sporadic_budget_TSR':
c:/rtems-4.10/cpukit/posix/src/pthread.c:82: error: 'struct sched_param'
has no member named 'sched_ss_init_budget'
c:/rtems-4.10/cpukit/posix/src/pthread.c:109: error: 'struct
sched_param' has no member named 'sched_ss_repl_period'
'_POSIX_Threads_Sporadic_budget_callout':
c:/rtems-4.10/cpukit/posix/src/pthread.c:132: error: 'struct
sched_param' has no member named 'sched_ss_low_priority'
make[5]: *** [src/libposix_a-pthread.o] Error 1
This "struct sched_param" is defined in the compiler rtems includes from:
/opt/rtems-4.10/arm-rtems4.10/include/sys/sched.h as:
> /* Scheduling Parameters, P1003.1b-1993, p. 249
> NOTE: Fields whose name begins with "ss_" added by P1003.4b/D8, p. 33. */
> struct sched_param {
> int sched_priority; /* Process execution scheduling priority */
> #if defined(_POSIX_SPORADIC_SERVER)
> int ss_low_priority; /* Low scheduling priority for sporadic */
> /* server */
> struct timespec ss_replenish_period;
> /* Replenishment period for sporadic server */
> struct timespec ss_initial_budget; /* Initial budget for sporadic server */
> #endif
And it does not have the extra parameters defined.
It looks like the prebuilt mingw tools are out of sync with the 4.10 source.
We can built this bsp using Ubuntu where the tools were built in house
using all the RTEMS patches.
regards,
Ian C.
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9444 2634
