RTEMS 4.10 Autoconf tools
Ralf Corsepius
ralf.corsepius at rtems.org
Fri Sep 10 06:41:51 UTC 2010
On 09/10/2010 08:02 AM, Yann Sionneau wrote:
> Hi,
> I had the same errors, it turned out to be because I compiled gcc with an outdated version of newlib.
> A simple fix that worked for me was to compile gcc with the latest newlib source code.
> I followed this tutorial on rtems wiki page : http://www.rtems.com/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu
Several details of these instructions are broken and many details are
missing ...
As I already wrote, with Ubuntu you're basically on your own.
Don't get me wrong, this is no bad will, it's just an effect of
mefavoring rpm-based over deb-based Linux distros (I consider rpm
technically superior to deb) and my time being limited (Remember: I am
doing all this on a volunteer basis).
I recommend to re-use the CentOS5 rpms under Ubuntu/Debian.
Ralf
