posix message queues
    Sebastian Huber
    Fri Sep 10 15:26:03 UTC 2010
On 09/10/2010 05:02 PM, Lisa A. Day wrote:
> Hi All,
> I'm experiencing some oddities with the posix msqs, which I'm hopefully
> missing some simple tips to overcome (hopefully not missing the point
> all together) .
> 1)  In my app, the API is extremely picky about names - "/" plus 6
> characters -- only. Is this correct? I can deal with it, but it took
> some time to figure it out.
Which errno value do you observe in case your name is longer than that?
> 2) I can spawn mulitple threads from the POSIX_init process no problem,
> but I can't spawn a thread from one of its child processes. Is there a
> trick or caveat to accomplishing this?
We have only one process in RTEMS, but may have multiple tasks (or threads).
Which errno value do you observe? Check the CONFIGURE_MAXIMUM_POSIX_THREADS
configuration option.
> Thanks - and if anyone knows of some good tech notes or documentation
> for this API that I haven't found, that would be helpful...
http://www.opengroup.org/onlinepubs/000095399/basedefs/mqueue.h.html
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
