How do I use rtems_termios_bufsize?! No doc!
João Rasta freakforever at gmail.com
Fri Sep 24 14:04:48 UTC 2010
The filename is console.c. I'm using rtems 4.10 from
ftp://gaisler.com/gaisler.com/rcc/src/
Best,
JM
On Fri, Sep 24, 2010 at 1:13 PM, Sebastian Huber <
> On 09/24/2010 02:01 PM, João Rasta wrote:
> > Hi,
> > I have checked the termios configuration again, it seems ok. No software
> > flow control, no canonical mode. Also the same configuration works fine
> > on a x86.
> > I'm using gaisler's console driver and when i opened the rtems driver
> > file it said this:
> What is the file name path of this file and the CVS version in your case?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100924/65a54901/attachment-0001.html>
