How do I use rtems_termios_bufsize?! No doc!
Sebastian Huber
Fri Sep 24 14:15:38 UTC 2010
On 09/24/2010 04:04 PM, João Rasta wrote:
> The filename is console.c. I'm using rtems 4.10 from
> ftp://gaisler.com/gaisler.com/rcc/src/
There are 48 console.c files in this archive.
> Best,
> JM
> On Fri, Sep 24, 2010 at 1:13 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 09/24/2010 02:01 PM, João Rasta wrote:
> > Hi,
> > I have checked the termios configuration again, it seems ok. No
> software
> > flow control, no canonical mode. Also the same configuration works
> fine
> > on a x86.
> > I'm using gaisler's console driver and when i opened the rtems driver
> > file it said this:
> What is the file name path of this file and the CVS version in your
> case?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
