How do I use rtems_termios_bufsize?! No doc!
João Rasta
freakforever at gmail.com
Fri Sep 24 14:25:56 UTC 2010
Sorry, it is this one:
rtems-4.10-mingw\src\rtems-4.10\c\src\lib\libbsp\sparc\leon3\console
On Fri, Sep 24, 2010 at 3:15 PM, Sebastian Huber <
> On 09/24/2010 04:04 PM, João Rasta wrote:
> > The filename is console.c. I'm using rtems 4.10 from
> > ftp://gaisler.com/gaisler.com/rcc/src/
> There are 48 console.c files in this archive.
> > Best,
> > JM
> > On Fri, Sep 24, 2010 at 1:13 PM, Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 09/24/2010 02:01 PM, João Rasta wrote:
> > > Hi,
> > > I have checked the termios configuration again, it seems ok. No
> > software
> > > flow control, no canonical mode. Also the same configuration works
> > fine
> > > on a x86.
> > > I'm using gaisler's console driver and when i opened the rtems
> driver
> > > file it said this:
> > What is the file name path of this file and the CVS version in your
> > case?
> > Sebastian Huber, embedded brains GmbH
> > Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> > Phone : +49 89 18 90 80 79-6
> > Fax : +49 89 18 90 80 79-9
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > rtems-users mailing list
> > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20100924/a5355879/attachment-0001.html>
