Ethernet Layer communications
Wolfram Wadepohl Wolfram.Wadepohl at ek-automation.com
Mon Apr 18 06:24:32 UTC 2011
You hit it. I have to implemet an 'ip in ip' tunnel and there is the
question to do it with RTEMS or do it without. I looked for raw sockets
rather than bpf. But the stack does not support it.
I'm very interested in coordinated efforts.
Brett Swimley schrieb:
> Hi All,
> I'm attempting to add Ethernet Layer communications to an interface, but
> I am unsure if there is an API exposed for doing this in the current
> networking stack.  I'm considering porting libpcap to RTEMS to
> accommodate this, unless there's an easier way.
> So I'm wondering:
> Is there a way to both send and receive Ethernet layer packets with the
> existing API and if not...
> Has anyone ported libpcap to RTEMS?  I'm considering doing this, as the
> licensing is BSD with no advertising clause, but if someone has already
> done this, would they be willing to provide code for doing this?
> Thanks in advance,
> Brett Swimley
> rtems-users mailing list
> rtems-users at rtems.org
Schöne Grüße aus Reutlingen
Wolfram Wadepohl
Forschung & Entwicklung
E&K AUTOMATION
Indumat GmbH & Co. KG
Siemensstraße 3
72766 Reutlingen
Deutschland
Tel.  +49 7121 514-289
Fax   +49 7121 514-299
eMail Wolfram.Wadepohl at ek-automation.com
       W.Wadepohl at ieee.org
WWW   http://www.ek-automation.com
       http://www.indumat.de
Diese Nachricht ist keine geschäftliche Mitteilung i. S. des EHUG.
Bitte senden Sie mir keine Word- oder PowerPoint- (tm Microsoft) oder OOXML
Anhänge.
Senden Sie mir einfachen Text, HTML oder PDF(ISO/IEC 32000).
Siehe http://www.gnu.org/philosophy/no-word-attachments.de.html
