Strange problem with newlib strstr function and rtems 4.10 on coldfire
Paul Whitfield
paulw at omnitronics.com.au
Mon Apr 18 04:28:46 UTC 2011
On 18/04/2011 10:51 AM, Paul Whitfield wrote:
> Hello All,
> I have a weird problem with the strstr function seeming to not work
> correctly on Rtems 4.10 with a Coldfire processor.
> The problem is that strstr appears to be matching on where there is no
> match!
Just some more info, if I import the strstr.c / str-two-way.h files
into my project and compile them locally I get the same issue.
However, if define PREFER_SIZE_OVER_SPEED in the strstr.c module, then
the code works as I expect and I get the correct match.
I have checked the newlib CVS and the version of strstr.c and
str-two-way.h in RTEMS4-10 are update to date with the most current
version.
One last note: Recompiling the strstr.c / str-two-way.h code newlib code
on the PC the code works correctly with the optimised version.
Regards
Paul
Message protected by MailGuard: e-mail anti-virus, anti-spam and content filtering.http://www.mailguard.com.au/mg
