Adding a new BSP
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 19 13:27:09 UTC 2011
On 04/19/2011 05:09 AM, first name wrote:
> Hi,
> I am developing a BSP for an in house PowerPC board and I can't
> understand
> how to add its name to the list of BSPs so that when I run the
> configure script I
> can put --enable-rtemsbsp=MyBSPName.
If you are on 4.10 or newer, the MyBSPName is detected automatically based
upon the set of files with a name like this:
libbsp/powerpc/MyBSPFamilyName/make/custom/MyBSPName.cfg
You can build multiple variants of a single BSP and that makes
a BSP directory represent a family. The ".cfg" file is the specific
name of the BSP you can build.
> Please can someone explain what to do or point me in the direction of
> the relevant document?
There is a BSP and Device Driver Guide in the document set.
The general approach is to find a BSP that is close and either make your
custom board a variation of that. If your board is close then you add a
make/custom file and then account for the differences via a combination
of configure time selection and conditional compilation.
If your board is not close enough to be a variation, then you make a new
BSP family directory and populate it. Start by copying from BSPs that
are similar.
If you need help, this is the type of consulting I like to do. Pair
programming
a BSP is a very efficient way to get one. You know that hardware and we
know the structure of the BSP and RTEMS issues.
> Thanks very much
> Roger Tarring
Joel Sherrill, Ph.D. Director of Research& Development
