[PATCH][rtems-testing] add gcj test support for RTEMS
Jie Liu lj8175 at gmail.com
Thu Aug 18 15:33:24 UTC 2011
Hi,
As a part of "RTEMS port of the GNU Java Compiler" project[1], I
should augment scripts in rtems-testing for gcj.
And the libjava patch has been merged[2], I think it's time to send
out the rtems-testing patch, the patch has been attached.
[1]http://www.rtems.org/wiki/index.php/GNUJavaCompiler
[2]http://gcc.gnu.org/ml/java-patches/2011-q3/msg00055.html
Best Regards,
Jie
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20110818/24359255/attachment.obj>
