[PATCH][rtems-testing] add gcj test support for RTEMS
Thu Aug 18 15:45:30 UTC 2011
Could you please file a PR with the patch, changelog entry, etc? That way it won't get lost even if it takes a while to get to it.
--joel
Jie Liu <lj8175 at gmail.com> wrote:
>Hi,
>As a part of "RTEMS port of the GNU Java Compiler" project[1], I
>should augment scripts in rtems-testing for gcj.
>And the libjava patch has been merged[2], I think it's time to send
>out the rtems-testing patch, the patch has been attached.
>[1]http://www.rtems.org/wiki/index.php/GNUJavaCompiler
>[2]http://gcc.gnu.org/ml/java-patches/2011-q3/msg00055.html
>Best Regards,
>Jie
