installation of RTEMS
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Aug 2 18:47:50 UTC 2011
On 08/02/2011 01:43 PM, Gedare Bloom wrote:
> http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
> Or try some of the getting started guides
> http://www.rtems.com/wiki/index.php/GSoC_Getting_Started
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/
If you are using a VM for RTEMS development, use
the Fedora 14 VM and do updates on it once you
get it running.
FWIW There must be a link to the Fedora 12 VM image
around somewhere. If you see it, tell us. Please don't
use it. It is old.
Inside the VM running the RTEMS Development Environment
on a GNU/Linux installation, you can run RTEMS itself on
a CPU simulator like sparc/sis or qemu. Those are set up
and should just work.
--joel
> On Tue, Aug 2, 2011 at 2:35 AM, Asma Mehiaoui<asma.mehiaoui at yahoo.com> wrote:
>> Hello,
>> Somebody can help me to install RTEMS with virtual machine?
>> Best Regards
>> Asma
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D. Director of Research& Development
