Can't build RTEMS-4.10 toolchain on OS X Lion
Ralf Corsepius
ralf.corsepius at rtems.org
Wed Aug 24 16:00:32 UTC 2011
On 08/24/2011 05:16 PM, Eric Norum wrote:
> I'm also having troubles building the tool chain for RTEMS-4.10.
> Things work fine until the compiler starts to work on libgcc:
> checking whether ln -s works... yes
> checking for m68k-rtems4.10-gcc... /usr/local/rtems/BuildTools/build/./gcc/xgcc -B/usr/local/rtems/BuildTools/build/./gcc/ -nostdinc -B/usr/local/rtems/BuildTools/build/m68k-rtems4.10/newlib/ -isystem /usr/local/rtems/BuildTools/build/m68k-rtems4.10/newlib/targ-include -isystem /usr/local/rtems/BuildTools/gcc-4.4.6/newlib/libc/include -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/bin/ -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/lib/ -isystem /usr/local/rtems/rtems-4.10/m68k-rtems4.10/include -isystem /usr/local/rtems/rtems-4.10/m68k-rtems4.10/sys-include
> checking for suffix of object files... configure: error: in `/usr/local/rtems/BuildTools/build/m68k-rtems4.10/libgcc':
> configure: error: cannot compute suffix of object files: cannot compile
> See `config.log' for more details.
Please check the contents of this file (Likely
/usr/local/rtems/BuildTools/build/m68k-rtems4.10/libgcc/config.log)
Ralf
