Can't build RTEMS-4.10 toolchain on OS X Lion
Ralf Corsepius ralf.corsepius at rtems.org
Thu Aug 25 11:33:14 UTC 2011
On 08/24/2011 06:00 PM, Ralf Corsepius wrote:
> On 08/24/2011 05:16 PM, Eric Norum wrote:
>> I'm also having troubles building the tool chain for RTEMS-4.10.
> Please check the contents of this file (Likely
> /usr/local/rtems/BuildTools/build/m68k-rtems4.10/libgcc/config.log)
Eric sent me his config.log on PM.
It shows his build is dying because the freshly built cross-compiler ICEs:
configure:2611: /usr/local/rtems/BuildTools/build/./gcc/xgcc
-B/usr/local/rtems/BuildTools/build/./gcc/ -nostdinc
-B/usr/local/rtems/BuildTools/build/m68k-rtems4.10/newlib/ -isystem
/usr/local/rtems/BuildTools/build/m68k-rtems4.10/newlib/targ-include
-isystem /usr/local/rtems/BuildTools/gcc-4.4.5/newlib/libc/include
-B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/bin/
-B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/lib/ -isystem
/usr/local/rtems/rtems-4.10/m68k-rtems4.10/include -isystem
/usr/local/rtems/rtems-4.10/m68k-rtems4.10/sys-include -c -g -O2
conftest.c >&5
conftest.c:16: internal compiler error: in execute_ipa_pass_list, at
passes.c:1342
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
configure:2614: $? = 1
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME "GNU C Runtime Library"
| #define PACKAGE_TARNAME "libgcc"
| #define PACKAGE_VERSION "1.0"
| #define PACKAGE_STRING "GNU C Runtime Library 1.0"
| #define PACKAGE_BUGREPORT ""
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:2627: error: in
`/usr/local/rtems/BuildTools/build/m68k-rtems4.10/libgcc':
configure:2630: error: cannot compute suffix of object files: cannot
compile
Close to impossible for me to guess on the cause.
Any other MacOS users out there?
Do the rtems-4.10 toolchains build for other targets?
Ralf
