NULL call to _Workspace_Free() via _Objects_Extend_information at startup
Peter Dufault
dufault at hda.com
Mon Feb 28 23:33:56 UTC 2011
I'm trying to move my mpc5554 BSP from 4.9 to 4.10 and I'm bombing out early on where it is calling _Heap_Free with a NULL block. This is the CVS head from 2 days ago, I've checked and don't see any relevant changes.
Here's the backtrace where it's about to happen:
#0 _Objects_Extend_information (information=0x210373a8)
at ../../../../../../rtems-head/c/src/../../cpukit/score/src/objectextendinformation.c:209
#1 0x00081cf0 in _Objects_Initialize_information (information=0x210373a8,
the_api=OBJECTS_INTERNAL_API, the_class=0x2, maximum=0x1, size=0x74,
is_string=0x0, maximum_name_length=0x0)
at ../../../../../../rtems-head/c/src/../../cpukit/score/src/objectinitializeinformation.c:156
#2 0x0007cbd8 in _API_Mutex_Initialization (maximum_mutexes=0x1)
at ../../../../../../rtems-head/c/src/../../cpukit/score/src/apimutex.c:23
#3 0x0007b76c in rtems_initialize_data_structures ()
at ../../../../../../rtems-head/c/src/../../cpukit/sapi/src/exinit.c:125
#4 0x00026724 in boot_card (cmdline=0x0)
at ../../../../../../../../rtems-head/c/src/lib/libbsp/powerpc/mpc55xxevb/../../shared/bootcard.c:163
#5 0x00000134 in start ()
at ../../../../../../../../rtems-head/c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start.S:219
(gdb)
"information" is a pointer to _API_Mutex_Information, and its object_blocks member was set to 0 in _Objects_Initialize_information()
(gdb) print _API_Mutex_Information.object_blocks
$4 = (void **) 0x0
(gdb)
but _Objects_Extend_information() is saving that away:
209 old_tables = information->object_blocks;
(gdb) next
211 information->object_blocks = object_blocks;
(gdb) print old_tables
$5 = (void *) 0x0
(gdb)
And if we continue a bit it's going to unconditionally call _Workspace_Free()
Breakpoint 5, _Objects_Extend_information (information=0x210373a8)
at ../../../../../../rtems-head/c/src/../../cpukit/score/src/objectextendinformation.c:224
224 _Workspace_Free( old_tables );
(gdb)
and that's all, folks. Does anyone recognize what I might have done to get in this mess?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
