PowerPC specific GCC patch question
Ralf Corsepius
ralf.corsepius at rtems.org
Mon Feb 14 16:33:04 UTC 2011
On 02/14/2011 11:09 AM, Sebastian Huber wrote:
> Hello,
> in contrib/crossrpms/patches/gcc-core-4.5.2-rtems4.11-20101216.diff we have this:
> diff -Naur gcc-4.5.2.orig/gcc/config/rs6000/rtems.h
> gcc-4.5.2/gcc/config/rs6000/rtems.h
> --- gcc-4.5.2.orig/gcc/config/rs6000/rtems.h 2007-08-02 12:49:31.000000000 +0200
> +++ gcc-4.5.2/gcc/config/rs6000/rtems.h 2010-12-17 16:16:29.575213615 +0100
> @@ -49,8 +49,22 @@
> %{mcpu=604: %{!Dppc*: %{!Dmpc*: -Dmpc604} } } \
> %{mcpu=750: %{!Dppc*: %{!Dmpc*: -Dmpc750} } } \
> %{mcpu=821: %{!Dppc*: %{!Dmpc*: -Dmpc821} } } \
> -%{mcpu=860: %{!Dppc*: %{!Dmpc*: -Dmpc860} } }"
> +%{mcpu=860: %{!Dppc*: %{!Dmpc*: -Dmpc860} } } \
> +%{mcpu=8540: %{!Dppc*: %{!Dmpc*: -Dppc8540} } }"
> #undef SUBSUBTARGET_EXTRA_SPECS
> #define SUBSUBTARGET_EXTRA_SPECS \
> { "cpp_os_rtems", CPP_OS_RTEMS_SPEC }
> +#undef SUBSUBTARGET_OVERRIDE_OPTIONS
> +#define SUBSUBTARGET_OVERRIDE_OPTIONS \
> + do { \
> + if (TARGET_E500) \
> + rs6000_float_gprs = 1; \
> + } while(0)
> +#undef WCHAR_TYPE
> +#undef WCHAR_TYPE_SIZE
> Why do we set SUBSUBTARGET_OVERRIDE_OPTIONS in that way?
The reason is this (from gcc/config/rs6000/e500.h)
#define TARGET_E500 (rs6000_cpu == PROCESSOR_PPC8540)
#define TARGET_FPRS (rs6000_float_gprs == 0)
#define TARGET_E500_SINGLE (TARGET_HARD_FLOAT && rs6000_float_gprs == 1)
#define TARGET_E500_DOUBLE (TARGET_HARD_FLOAT && rs6000_float_gprs == 2)
#define CHECK_E500_OPTIONS \
do { \
if (TARGET_E500 || TARGET_SPE || TARGET_SPE_ABI \
|| TARGET_E500_SINGLE || TARGET_E500_DOUBLE) \
if (TARGET_ALTIVEC) \
error ("AltiVec and E500 instructions cannot coexist"); \
if (TARGET_VSX) \
error ("VSX and E500 instructions cannot coexist"); \
if (TARGET_64BIT) \
error ("64-bit E500 not supported"); \
if (TARGET_HARD_FLOAT && TARGET_FPRS) \
error ("E500 and FPRs not supported"); \
} while (0)
in combination with this (from the rtems-patch):
MULTILIB_OPTIONS = \
-mcpu=403/mcpu=505/mcpu=601/mcpu=603e/mcpu=604/mcpu=860/mcpu=7400 \
+mcpu=403/mcpu=505/mcpu=601/mcpu=603e/mcpu=604/mcpu=860/mcpu=7400/mcpu=8540
Note: mcpu=8540 matches TARGET_E500
> The e500v2 supports
> 64-bit floating point operations.
> With this setting I am not able to use this
> feature.
Yep, the current rtems-patch doesn't take this into account.
=> This "if" would have to be extended.
Ralf
