Network support with POSIX API
João Rasta
freakforever at gmail.com
Mon Jan 3 17:16:12 UTC 2011
Hi,
I'm using RTEMS with POSIX API and now i'm trying to setup the RTEMS network
support in order to perform TCP/IP communications.
When i do:
rtems_bsdnet_initialize_network ()
I get the following error, happening in rtems_bsdnet_newproc() function of
rtems_glue.c.
Can't create network daemon `ntwk': `too many'
fatal error, exiting
Is this a failure on rtems_task_create() because i'm using standard POSIX
API? If so, is there a way to configure network support for POSIX API?
Best,
JM
URL: <http://lists.rtems.org/pipermail/users/attachments/20110103/47f41d0f/attachment.html>
