Network support with POSIX API
Eric Norum wenorum at lbl.gov
Mon Jan 3 17:44:36 UTC 2011
You need to increase the number of tasks in the system.
The error message is reporting the inability to start a network-related task -- and reporting that the failure was the result of trying to start too many tasks.
On Jan 3, 2011, at 9:16 AM, João Rasta wrote:
> Hi,
> I'm using RTEMS with POSIX API and now i'm trying to setup the RTEMS network support in order to perform TCP/IP communications.
> When i do:
> rtems_bsdnet_initialize_network ()
> I get the following error, happening in rtems_bsdnet_newproc() function of rtems_glue.c.
> Can't create network daemon `ntwk': `too many'
> fatal error, exiting
> Is this a failure on rtems_task_create() because i'm using standard POSIX API? If so, is there a way to configure network support for POSIX API?
> Best,
> JM
> rtems-users mailing list
> rtems-users at rtems.org
Eric Norum
wenorum at lbl.gov
