Status of Networking Driver Milkymst One BSP
Yann Sionneau yann at minet.net
Mon Jan 24 09:06:41 UTC 2011
Hi Cristian,
for TCP tests you have the "milkymist_networking" test inside the
testsuites/samples of my git repository.
You can find informations about how to run those tests (at least on
Qemu) on this page :
http://www.milkymist.org/wiki/index.php?title=Run_RTEMS_sample_applications_on_the_Milkymist_One_board_and_on_Qemu
You can do a telnet and get a RTEMS shell.
I can find no reason why it wouldn't work on the board, so you can test
those tests on the board too and let me know what happens :)
Regards,
Yann Sionneau
Le 23/01/11 01:48, Cristian Paul Peñaranda Rojas a écrit :
> Hi Fallenou and rtems user list !,
> Can you tell us a bit more of the status/know issues/TODO about the
> Networking Driver for the Milkymist One BPS?.
> I had been doing/following some basic tests of the rtems network capabillities,
> mainlly following some info [1].But  seems the wiki just point what really
> works (tftpclient) because, so far i dint manage (lucky?) to stablish at least a
> telnet/httpd TCP session :'(.
> Surpriselly ICMP echo reply is ok, beside that s that the only trafic
> i got from my M1 a running a telnet test is a Gratuitous ARP package
> broadcasting the mac and ip of the device, but if i try both telnet or netcat against
>   a 23/80 tcp port i never pass from sending SYN and no reply from rtems IP.
> Is this a problem related just with TCP part?, (i dint made UDP tests yet),
> what can i do to help?, i just starting reading seriosly rtems docs,
> today, but i really need serious support for TCP/IP comunication for my
> project.
> Anyway, i'll keep you posted in case i found something else
> Saludos
> Cristian Paul
> [1] http://www.rtems.com/wiki/index.php/Milkymist
