Compiling the RTEMS HEAD
    Claus, Ric
    claus at slac.stanford.edu
    Tue Jan 25 03:35:34 UTC 2011
Hi All,
  Back in October, I was able to compile RTEMS out of the box (.bz2 file), however, recently (since at least the turn of the year), I've not been successful.  I have the same trouble with the CVS HEAD.  My target platform is powerpc/virtex.
Below is a dump of the crash.  The version of GCC on a RHEL 5 build machine is:
$ gcc --version
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-50)
I've traced the issue down to the <math.h> installed on this system wanting to have the __USE_ISOC99 macro defined before it will include <bits/huge_valf.h> (and various other files).  The simple way out is to define the macro _ISOC99_SOURCE, which will in turn cause the other one to be defined (see <features.h>), but I'll venture that that's probably not the right solution.  Would someone please point me to a proper way to fix this?
  Apologies for the newbe question, but if this is the wrong forum to post such questions, please redirect me.
Thanks,
               Ric Claus
gcc -DPACKAGE_NAME=\"rtems-tools-schedsim\" -DPACKAGE_TARNAME=\"rtems-tools-schedsim\" -DPACKAGE_VERSION=\"4.10.99.0\" -DPACKAGE_STRING=\"rtems-tools-schedsim\ 4.10.99.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -DPACKAGE_URL=\"\" -I. -I../../../../RTEMS/tools/schedsim/rtems  -D__RTEMS_VIOLATE_KERNEL_VISIBILITY__ -I../../../../RTEMS/tools/schedsim/rtems/sched_cpu -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/include -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/score/include -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/score/inline -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/rtems/include -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/rtems/inline -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/sapi/include -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/sapi/inline -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libcsupport/include -I../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libmisc/stringto   -g -O2 -MT librtems_a-stringtofloat.o -MD -MP -MF .deps/librtems_a-stringtofloat.Tpo -c -o librtems_a-stringtofloat.o `test -f '../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libmisc/stringto/stringtofloat.c' || echo '../../../../RTEMS/tools/schedsim/rtems/'`../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libmisc/stringto/stringtofloat.c
In file included from ../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libmisc/stringto/stringtofloat.c:24:
../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libmisc/stringto/stringto_template.h: In function 'rtems_string_to_float':
../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libmisc/stringto/stringto_template.h:120: error: 'HUGE_VALF' undeclared (first use in this function)
../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libmisc/stringto/stringto_template.h:120: error: (Each undeclared identifier is reported only once
../../../../RTEMS/tools/schedsim/rtems/../../../cpukit/libmisc/stringto/stringto_template.h:120: error: for each function it appears in.)
gmake[2]: *** [librtems_a-stringtofloat.o] Error 1
gmake[2]: Leaving directory `/reg/common/package/rtems/4.11/build/tools/schedsim/rtems'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/reg/common/package/rtems/4.11/build/tools/schedsim'
make: *** [all-recursive] Error 1
