Why object's name is so short?
Mon Jan 24 17:30:07 UTC 2011
On 01/24/2011 10:57 AM, Mozzhuhin Andrei wrote:
> Hi
> RTEMS uses the object ID (rtems_id) for management of any objects.
> Additionally, each object has a name that is used mainly for display to
> the human. They both have a size of 4 bytes.
> Why object's name (intended for the human) is so short?
Because the specifications RTEID and ORKID which
RTEMS was originally based upon required this.  pSOS+
and VMEExec were also based upon this standard.
I recall that Nucleus is from the same API vein.
Wendell is right.  It does reduce memory and string
error chances.  You can use rtems_build_name()
which takes 4 characters to have some readability.
> Thanks
> Andrei Mozzhuhin
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&  Development
