RTEMS Port of GCJ Progress Report
Jie Liu
lj8175 at gmail.com
Fri Jul 8 17:31:26 UTC 2011
Hi,
This is the second report after “GCJ Porting for RTEMS Status
Report”[1]. During this time, I am
--- Focusing on running the testsuite and fix encountered problem
--- Submitting patches to related community
In details, I have got the testsuite result for boehm-gc, libffi and
libjava, which can be seen in rtemsgcj project’s trunk[2]. For
problems encountered in boehm-gc, they are fixed under Ivan’s help,
and the problems can be seen in mailing list[3](Just search rtems for
related information). For problems encountered in libjava, I have send
a mail to java-patches[4], some problems have been fixed while others
still in fixing.
The patches have been send to related communities, although libjava’s
patch still needs modify. For boehm-gc, the patch can be seen on
java-patches mailing list[5]. For RTEMS, the patch can be seen on
RTEMS mailing list[6]. For libjava, the patch also can be seen on
java-patches mailing list[7]. The libffi is worked on RTEMS/i386, so
there is no patch for it.
Next step, I will
+++ Make as more libjava test case PASS as possible and get the
libjava patch merged
+++ Move to a new architecture and repeat the porting progress
If you have any ideas on this project, please do not hesitate to contact me. :)
[1] http://www.rtems.org/pipermail/rtems-users/2011-June/008574.html
[2]http://rtemsgcj.googlecode.com/svn/trunk/gcjtest/testsuite_out
[3] http://news.gmane.org/gmane.comp.programming.garbage-collection.boehmgc
[4] http://gcc.gnu.org/ml/java-patches/2011-q3/msg00016.html
[5] http://gcc.gnu.org/ml/java-patches/2011-q2/msg00067.html
[6] http://www.rtems.org/pipermail/rtems-users/2011-June/008573.html
[7] http://gcc.gnu.org/ml/java-patches/2011-q3/msg00001.html
Best Regards,
Jie
