RTEMS image size question
Matthews, Lee
l.matthews at imperial.ac.uk
Wed Jul 13 15:28:53 UTC 2011
Hi,
I'm developing some software that uses RTEMS on an Aeroflex Gaisler LEON3 processor that is running on a Pender GR-CPCI-AX2000 development board.
I use the following statement to compile my source code : sparc-rtems-gcc -O2 -g sourcecode.c -o outputexecutable.exe
My image files always seem to be rather large (about 150Kbytes), even for rather simple code - is this normal ?
So for example, I modified the provided sample source file rtems-hello.c to look like the following :
/* configuration information */
#define CONFIGURE_INIT
#include <bsp.h> /* for device driver prototypes */
rtems_task Init( rtems_task_argument argument); /* forward declaration needed */
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 4
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_EXTRA_TASK_STACKS (3 * RTEMS_MINIMUM_STACK_SIZE)
#include <rtems/confdefs.h>
rtems_task Init(rtems_task_argument ignored)
exit( 0 );
Yet, when I compile the code and look at its size using sparc-rtems-size it comes out as :
sparc-rtems-size rtems-hello.exe
text data bss dec hex filename
136736 4068 4736 145540 23884 rtems-hello.exe
I do not understand why the image size is so big, given the lack of the visible code's complexity. Is everything compiled in by default? Do I need to explicitly remove the bits from RTEMs that I don't need? How can I reduce the image size?
Any help or guidance would be much appreciated.
Thanks in advance,
Lee
URL: <http://lists.rtems.org/pipermail/users/attachments/20110713/4fad3749/attachment.html>
